does anyone have a complete lisgt and or part numbers for a 5 speed swap into a V-6 alero? any hel appreciated
5 speed swap for a v6 alero?
Here's what I know...
The 1995-1997 2.2l J-Body (Cavalier/Sunfire) 5 speed MK7 -- aka Isuzu -- transmission will bolt right up to the 3400. You will need the shifter and cables from that car as well. Also, the clutch reservoir and piping, clutch pedal, flywheel, slave cylinder (it's internal) and clutch plates.
From there, not sure about CV axles if you will need 94-98 N-Body or if the J-Body ones will work. The tranny mounts will need to be changed. Your ECU will need to be reflashed to remove all auto trans settings. As for the rest of the details, I'm not sure...Last edited by Kardain; 12-31-2006, 04:19 AM.
i would stay away from the isuzu 5 speed myself. they are alright with a 4 cyl, but many people have diff problems as well as other breakage issues with a highly modded 4 cyl, so you can imagine what a v6 would do.
i would go with a 92-94 getrag 5 speed from a j-body v6, or a 2000-2002 getrag from a 2.2l j-body. either will bolt right up, and they are both good transmissions.
MM Have don that swap so I the list is as following:
A getrag from a 2001 sunfire or alero/grand am is ok because they can with stand more power than the Isuzo one.MM just use all of the part from a manual alero/grand am( Clutch padel, shifter and cabels from the same gearbox, flywheel, and all the other stuff. It's much easier to do this swap if you get like all the parts from a 2.4 alero/grand am.
And when you're finishi with that you need to reflash and retune you're ECU.
As far as the breakage goes, from what I've read, its usually third gear that dies. The diff can be swapped for one out of a Geo Storm (forged diff) if it should happen to break. The gearing can be changed up a bit as well...
However the route you want to take, theres the above options (and I'm sure there are more). Just whatever you decide, make sure you get all the parts you can out of the donor vehicle.
Originally posted by TurboAlero View PostMM Have don that swap so I the list is as following:
5 speed N bodys are somewhat difficult to locate. I currently have most of the parts needed to swap to a 5 speed but lack of time and a place have me thinking of selling what I have.
Some of my info can be found here:
2000 Grand Am GT
2011 Chevy Impala
