The 6spd clutch is at the top. Take note of the hot spot locations in the flywheel and how they corraspond with the areas of missing metal in the lip on the perimeter. The same thing happens to cylinder heads when you go hog wild on them during a porting session or at least to me when I did it to my chevy heads, didn't take long to make the connection with the higher temps.
Specs:
.................................4spd clutch vs. 6spd clutch
Friction surface: 9.13" OD, 6.12" ID ____ 9.45" OD, 6.12" ID measuring inner and outer dia of friction material.
Friction width: 1.5" disc, 1.65" pplate__ 1.66" disc, 1.825pp measuring width of friction material and pplate area.
Spline number:__14.._________________23 with 1" diameter shaft
Pressure plate: 5.87" ID, 9.18" OD______5.84"ID, 9.45" OD, measuring inner and outer dia of contact area.
Specs:
