steering wheel turns but tires dont
  • steering wheel turns but tires dont
    well well go ahead and laugh but i went to take the car out and the steering wheel turns but the wheels dont just wondering if i forgot too hook something up or if i did something wrong ............
    What did you do to your car. Sounds like the sterring shaft coupler was pulled apart. Did you have the subframe lowered at all?
    1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
      Yeah, thats exactly what it sounds like. That or the tie rods broke off...
        CAUTION
        bE CAREFULL ON HOW MANY TIMES you turn wheel either direction. You will break the airbag coil in column.
