2001 lesabre motor mount replacment tutorial?
  • 2001 lesabre motor mount replacment tutorial?
    Just got done replacing the rear trans mount...never had that much trouble with a mount before.
    I've tried looking for a online source for the repair process but all searches have turned up short. Can anyone either cut/paste the directions in here, or point to a source? I need instructions for the front/left mount(one by the radiator). And it isn't as simple as removing nuts, and jacking the engine up. Looks like a I'm going to have to drop the engine cradle for the front too. If you try jacking it up, the side mounts just bottom out and attempt to jack the whole frame up.
    Thanks in advance.
    Nevermind. I ended up up taking the bracket off which made it fairly easy. What looked like studs turned out to be bolts with threads on each end of the nut. Took those 3 out, and the bracket lifted right out(after removing the single nut on the mount).
