94 grand am gt death wobble
  • 94 grand am gt death wobble
    I've balanced tires (and rotated), replaced balljoints, replaced lower control arm bushings, the tierods are tight, and yet I am still getting a bad shake at 60mph. sometimes, it is better or worse, sometime when I'm going real slow (like ~5-10mph) it'll move the steering wheel back and forth like 2".
    could my rack and pinion be loose or going bad?? what are the symptoms?
    also, my front tires have a weird wear patten on the outside edge, like the toe in is real whacked, except that the wear pattern isn't constant, some spots are worn more than others.
    I figure it needs an alignment, but I don't think that will fix my shimmy.
    any ideas?
    \'94 grand am gt
    RE: 94 grand am gt death wobble
    I'd get it aligned, and get new tires. Sounds like a belt may have either shifted, or separated in one or more of the tires.
      "death wobble" Yeah sounds like the tires are f'd up.
        I've probably going to try the tires. however, I have had these tires on the back with no vibs in the back, only in the steering wheel.
        \'94 grand am gt
          my z26 did that nasty skake when the wheel bearing went crappy
          99 Grand Am GT
          1357 cam 227 233 .050 dur
          515 515 lift 112 lsa
