ABS wheel sensor
  • ABS wheel sensor
    Anybody know on a 94 cutlass Supreme if you can replace the rear abs wheel sensor without changing the bearing or hub.Just want to know if its attached or can it be changed.
    1995 Cutlass Supreme 3100 SFI
    Cold Air K&N Filter
    58mm TB
    Dynomax Duel Exhaust with Performance Catalytic Converter
    FFP Underdrive Crank Pulley
    1/4 mile 15.65 at 90.8 mph
