Im buying some slotted rotors and the guy wants to know the Diameter of my rotors.Anyway the stock rotors for a 94 Cutlass fronts are 267mm(10 1/2) inches Diameter but he also has a set that are 286 mm(11 1/4inches).Does any one know if the 11 1/4 diameter rotors will fit, is there enough room.Thanks jeremy
P.S If anyone wants to convert mm to inches just divide mm by 25.4 .That will give you the most accurate number.If you want to go from inches to mm just times inches by 25.4 for mm.
Example 267mm divided by 25.4 =10.511 inches rounded to thous
Example 10 inches x 25.4 = 254mm
