2nd gen rear disc conersion
  • 2nd gen rear disc conersion
    Are there any cars that I couls swap from or do I have to go aftermarket?
    I am updating to the phase2 gen2 cavy brakes for the fron gain an inch of rotor and would like the rear to compliment the set up
    i wouldnt bother doing a 92+ brake upgrade,. it takes you from 9.5" to 10", and not realy worth it. there is another brake upgrade that uses caddy sts knuckles, balljoints, hubs, outer axle ends (you put them on the j body axles). it takes you to 11.25" rotors. the only downside of it is that you now need 5x115 bolt pattern wheels instead of 5x100 stock.
    anyways, rear discs arent easy. you can use pontiac 6000 ste rear brakes, but you need to cut the spindle off that axle and weld it to the stock axle.
      Well The caddy swap is defiantly out, I just got these 16 wheels last wear and can't afford another set of rims
      as for rear I may just save up for he rsm racing conversion kit
      thanks for your help, I'll have to do some more reserch and see if there is any other options out there
        rsm conversion??? i know they make a 3rd gen conversion, but it wont work on a 2nd gen, completly different.
          they make a second gen one two
