I do know that these brakes on these W body cars kinda sucks moose balls. It seems like you need to service them on a yearly basis or you have to replace rotors and or seized caliper sleeves/bolts. Is the design on the rear prone to water ingression?
One time I replaced the sleeves with these non metal ones, I think it was like light green ceramic which they say will never rust hence not seizing. Guess what? those ceramic ones seized as well, then you got the rotors rusting because the pads do not even touch the rotor surface. Besides removing them each year and disassembling and lubing it all up what do you use or special grease? I will need to replace the rear pads and rotors and not sure if the sleeves are seized again.
