im looking to upgrade my front brakes on my 86 z24 cavalier. now before i start, i already know there is the 92+ upgrade. i feel that going from 9.5"-10" is realy a waste of time and money, and the improvments will be marginal.
i was doing some looking and found that w body cars use 11" front brakes. i have done a lot of reasearch and it looks like the spindle will go on fine and wont be much hassle. i would need to use the w body hub as well being its 5x115 and the j body is 5x100 (i have dual bolt pattern 17" rims, so thats no big deal).
what im having trouble finding is info on the axles. are the outer axles the same as a j body (same diameter and spline count)??? this is the last thing i need before i got to get all of the parts from a donor car. and they arent the same, does anyone know if the w body outer can be used with the rest of the j body axle???
ive heard of someone using 11.25" from a cady seville, but the axles need to be custom. im not sure if its as simple as using the cady outer with the rest of the j body axle, or if it needs to be complete custom made.
