I was just wondering if this has been tried I want to know how difficult it would be to swap the rear suspension set-up from a 96-06 W-body including spindles, lateral arms, and trailing arms. I know that the 97-03 N-body can use the lateral arms from the W-body, and BMR suspension sells the upgraded poly/ 1 3/4" tubular lateral arms and as well as the trailing arms. My question is, how difficult would it be to do a full suspension swap, I twisted one of my stamped steel flimsy lateral arms, and now need to replace it, my solution is to upgrade anything that goes bad, so has anyone tried this or is it not do-able? The struts look the same so my KYB's should bolt right up, or will those have to be improvised as well as far as strut mounts??? I would like to swap over to the W-body setup since there is far more options as far as performance brakes and suspension componets than there is for the N-body.
I took some pictures of a customer's car today at work, I know that this spindle isn't set up for disc brakes but the disc spindles' suspension mounting locations will be the same.
TCA012 - Lateral Arms, Adjustable, Rear, Forward Mount
TCA013 - Lateral Arms, Adjustable, Rear, Rearward Mount
TCA011 - Trailing Arms, Rear, Polyurethane Bushings
Stock W-body
Trailing Arm Mounting locations
Spindle to strut mounting locations
Stock W-body
