What a royal PITA!!!
I am stuck and need advise on how to continue....This is where I am at.
CAB
- Steering column removed
- Various wires and boxes removed
- Brake pedal disconnected from Vac Booster through firewall
- Various trim pieces removed
- Dash Cluster removed
ENGINE BAY
- Brake Master removed
- Vac Booster removed
- 4 large nuts holding the pedal assembly removed
The pedal assembly is free from connections and only needs unbolted (somehow). I really tore down into the cab so far but feel I need to do more. BUT I don't want to remove more if I am going down the wrong path.
Am I missing something or do I need to take the entire dash down? I must remove the pedal assembly.
It is part of the 5-Speed swap and there are no visible bosses for the clutch that I can see/feel.
The Haynes Manual doesn't seem to cover this stuff.
CAB
ENGINE BAY
