hey im planning on gettin a rear sway bar for my 94 NBod im still using the stock front bar but i put new polyurth endlinks on there. I was trying to decide between an addco rear bar and manta part. the addco is a 1" diameter bar which equates to a lil over 26 mm. the mantapart bar is a 26 mm bar. the addco is 45$ less but i thought the manta bar would be better quality anyone got some input? the only other issue is that the addco is for 85-94 and i did a 95 grand am sedan rear suspension conversion so it may not fit anyway. but i was just seeing if anyone has input on the manuf. and their products
rear sway bar
The Mantapart one is probably just an Addco (or other brand) that they sell for a higher price. That's what half of their stuff is anyway.-Brad-
Originally posted by extremeskiier728there was no sway bar on either at least no stock one
I'd like to know what syspention you had stock. Is it FE1 FE2 or FE3 ?
To find the RPO codes look under the spare tire cover.
FE1 : SUSPENSION SYSTEM, SOFT RIDE
FE2 : SUSPENSION SYSTEM, RIDE HANDLING
FE3 : SUSPENSION SYSTEM, SPORT
Even FE1 has sway bars.
Here is some more information on N-body suspention
all i know is i had a 95 sedan SE and bought set of sprint springs crashed that car bout 94 coupe SE and the front was the same rear had smaller beams and such and had smaller cone shaped springs so i converted to the 95 rear which has cylidrical springs if i have a chance ill take a pic of the rear set up
ok well i checked it out and i have the fe2 set up right now i didnt realize that the sway bar was inside the main beam like that however the old suspension is supposedly fe2 as well allthe the rear beams and springs and everything were diff. so im just gonna go with a 95 sway bar since thats whats on there right now
