The car is an unmolested 1997 malibu.
The goal is a lot better on road performance.
I would like to fit somewhat larger overall diameter and wider tires 235/60R15, yet maintain the stock 15" rim size. It looks like there is plenty of room to go wider to the outside and only a tad bit inward. I'm considering 8" wide as my minimum goal, I'll roll the fenders to fit. Custom steel wheels are going to be the rim of choice for now, ie. rehoop the stock steel wheels.
This means that I will also want to lower the car 1" to bring it back to its regular ride height, maybe slightly lower (2" maximum), I do not want the gangbanger look or ricer look. I can't seem to locate true coilovers and am not sure I want to spring for a custom set at the moment (I wan't to do brake upgrades first
). So any strut mods that allow a larger diameter tire and a similar drop would be great, I'm at a loss here. I have heard of a modification to the struts rod where it is machined shorter to keep it from bottoming out in the cylinder, in this case 1 or 2 inches. Thoughts?
I can't cope with the sway in this car, spring options and larger swaybar options are a huge must. I'm no weekend racer, and I don't street race, but I do like to hit the back roads with a bit of speed when the time is there for me to have a bit of fun.
I can cope with a harsh ride if it gives back in increased traction and road feel. If anyone has done the work on spherical bearing replacements for the many bushings I'm all ears.
So to sum it up; larger/wider tires, zero (1") to 1" (2") drop to compensate for the larger tires, tighter suspension.
Thanks for your time guys,
Maurice Pudlo
). So any strut mods that allow a larger diameter tire and a similar drop would be great, I'm at a loss here. I have heard of a modification to the struts rod where it is machined shorter to keep it from bottoming out in the cylinder, in this case 1 or 2 inches. Thoughts?I can't cope with the sway in this car, spring options and larger swaybar options are a huge must. I'm no weekend racer, and I don't street race, but I do like to hit the back roads with a bit of speed when the time is there for me to have a bit of fun.
Maurice Pudlo
