Saggin' Transverse Spring
  • Saggin' Transverse Spring
    What parts do you guys use that have the transverse spring suspension to lift it up in the back? I got one on my 91 GP and it sags like you know what. Let know because everytime i look at it, it pists me off.
    I believe you can buy new pads for the spring perches. Should give it a bit of a lift.
    When I replaced my rear struts with gas charged ones the rear of the car perked up just a bit.
    1994 Corvette
    LT1/ZF6
    2006 Dodge Dakota 4x4
    3.7/42RLE
      ok now what does this look like, where can i get it and how much does it cost? What's involved installing them?
        i would think you could find them at rockauto...
          at this website, what do i type exactly to view this?
            i believe they are refered to as leaf spring bushings...
              ok i saw on the website a transverse isolator pad. do you know how they are installed and exactly how do they push up the height of the rear?
                isolator pad sounds like a pretty good technical term for it.
                  I have a FE3 rear spring from my 95 GTP. And I can remove the spring from my Z34 parts car if u wanted one. I believe the Z34 spring is FE3 as well. Just change the spring and it will raise the car back up and give it a better ride. Or just cut a coil and a half off the front to level it out.
                  Robert
                  New Rebuilt 3100
                  New Rebuilt 4T60-E
                  Exhaust
                  Drilled/Slotted Rotors
                  White
                  3" Magnaflow Catback
                  90 Pontiac Turbo Grand Prix
                  5 Speed Swapped
                  127,000
                  Spec Stage 3 Clutch
                  230,000 mile Getrag 282
                  Emissions Deleted
                  Brand new Engine 1,000 Miles
                  Fully Custom Built car
                    Do NOT cut coil springs!!
                    Very dangerous to begin with and ...well that is just GHETTO!
                    Replace the insolators, or swap out the spring. Heck do both!
                      ok lets try this, those white blocks by moog that you put on the ends of the transverse spring, have anyone tried that option yet and if so, do they work well?
                        The Moog helper springs help W bodies out really well, from what I've heard.
                          ok i've heard several options to fix a saggin' transverse spring but which one is the best? Does anyone have any pics of a fix up of either of the mentioned solutions to show? Let me know.
                            i would do both, but i would NEVER cut coils... anyone that does is asking for more trouble than good.
                              i put new struts in and my car sits about 1" higher than it used to in the ass end. no before after pics though. generally if you bought the car used from someone, its probably a good idea to replace the struts. mine were SHOT and as for the pads, well the thicker spacers you put in there, the higher its going to be, same thing with the curve of the spring.
                              we have a place in town that does leaf springs for trailers. as soon as i get around to getting an example spring out of the JY theyre going to make me something out of metal...
                              its not gonna cost me tooooo much either.
