*** W-BODY COIL-OVER UPPER SPRING PERCH ***
Look what I made up... Some upper coil over spring perches/mounts! I know there were a bunch of people a while back that were looking for these, and since they don't seem to be made anymore, here these are.
If there's interest, I have the ability to mass-produce these.
As you see, they're similar to the TDC mounts Josh (TurboSedan) from gmwbody.com had on his car, but these were designed a bit differently so they fit snug into the OEM-style strut mount. These have to be hammered into the OEM strut mount with a rubber mallet, or you can set it in there and slam the whole setup against a desk to wedge it in there. It comes out of the strut mount (if needed) with some slight prying from a screwdriver. IMO they should work better this way because they won't be resting on the springs, but we'll see....
