I (and probably others) need an explaination of backspacing. What the differece is between negative and positive backspacing, just so I'm certain before I jump into buying my new wheels. I know the bolt pattern is 5-115 (not 114.3).
I also have a question about the back spacing requirements. I'm looking at a set of 17's for my 92 Z34, and I think I read somewhere that anything under 38mm backspacing would fit... is that correct? If so, then this size should fit: 17X8 5-115 35C -- where 35 is the backspacing (in MM)... C just means chrome (according to that site).
So... back spacing less than 38 will push the wheel out more than stock?
Also has anyone ever owned a set of Voxx wheels? Any comments?
