I replaced the front struts on my roomate's '97 Nissan Maxima this weekend when I noticed the Maxima uses the exact same front end strut setup as the W-bodies, save for where the tie rod bolts up. It uses, as W-bodies do, drop in cartridges that are held in with a big nut. I just looked at Koni's online catalog and they make struts for his car, and they appear to be drop in inserts and come with the procedure for drilling out the bottom for the adjustment bolt, just like we had to do with the old struts. I didn't get a chance to look at the back , but the back would be easy to make Konis work compared to the front. AFAIK, strut cartridges have a universal diameter so they should fit in GM housings. Only question would be about length, but that should be fairly universal as well. If I had the money, I'd experiment with this, sadly I'm short of funds ATM. Anyone want to look into this?
May have found Konis to work in the W_body
Hmm, good findI started looking around and the weight comparison because it would have an effect on how much struts absorb bumps and stuff and found:
Lumina:
Curb weight 3496 lb (1586 kg)
96 Maxima SE
List weight (what the site said) 4,273 lbs
So set on hard, it's probably going to be one very harsh ride. BTW, my funds are virtually non existent. I have to wait for my next check to get my front shocks and twin I beam bushings for my truck to get it going again (shocks are cheap compared to struts, and bushings are $15 a side before my discount).-60v6's 2nd Jon M.
This will be great if it works!
This is history for us if we find it works!1991 Grand Prix STE
3.4 DOHC
1 of 792 Produced
Extensive Mods Done
1991 Lumina Z34
3.4 DOHC
Getrag 284 5spd
1 of 30
I wanted to just get a stock cartridge replacement for a Maixima to try in my car since it's apart, but all the stores around here only sell a complete new strut housing with insert already installed. Perhaps if someone could find just a gas insert from a local parts store and try it in a W-body housing they have lying around we'd have our answer. As long as you're careful you should be able to return it and just say it was the wrong part or something.
Lumina:
96 Maxima SE
List weight (what the site said) 4,273 lbsLast edited by OldSkoolGP; 03-15-2009, 10:22 PM.I may own a GTO now, but I'm still a 60V6er at heart.
For the fronts, there are konis that will drop right in. For the rear you will need to thread the tube and go from there. We are almost done with ours.
