This Bad?
  • Question : This Bad?
    As posted in the squeaking when hitting bump thread about my bad bushings on the rods that go from the support crossmember to the knuckle assembly i have this question/problem..
    Is This Bad?
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    Drilled/Slotted Rotors
    White
    3" Magnaflow Catback
    90 Pontiac Turbo Grand Prix
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    230,000 mile Getrag 282
    Emissions Deleted
    Brand new Engine 1,000 Miles
    Fully Custom Built car
    Is that the end on the leaf spring?
    1991 Grand Prix STE
    3.4 DOHC
    1 of 792 Produced
    Extensive Mods Done
    1991 Lumina Z34
    3.4 DOHC
    Getrag 284 5spd
    1 of 30
      Yes it is..
      Robert
      New Rebuilt 3100
      New Rebuilt 4T60-E
      Exhaust
      White
      5 Speed Swapped
      127,000
      Spec Stage 3 Clutch
      Emissions Deleted
        Looks like it has no rubber pad between the leaf and where it rests. If so, yes that is bad... sometimes they rot so much they just fall out. Not like your car is going to fall apart but that can definitely make noise. You need the NAPA solid replacement pads... there is a part number around here somewhere.
        SpudFiles
        Theopia
        Enjoy life online.
