Beretta steering rack
  • Question : Beretta steering rack
    Buying a beretta z26 tomorrow and the steering rack is messed... you can turn it a quarter turn each way left or right and the rack is moving not the tires.. the rack moves inside the rubber mounts.. So whats going on here..
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    Drilled/Slotted Rotors
    White
    3" Magnaflow Catback
    90 Pontiac Turbo Grand Prix
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    230,000 mile Getrag 282
    Emissions Deleted
    Brand new Engine 1,000 Miles
    Fully Custom Built car
    Probably rotted off the bulk head or the mounts busted off. They are not pleasant to do let a lone tack in new metal.
      if the mouns busted will it be easy to repair
      Robert
      New Rebuilt 3100
      New Rebuilt 4T60-E
      Exhaust
      White
      5 Speed Swapped
      127,000
      Spec Stage 3 Clutch
      Emissions Deleted
        Better hope its the mounts. To extract a broken bolt will require dropping the rack... In a V6 Beretta it gets involved.
          you wouldnt happen to have a pic around would you? and it is a v6 3100.. yay!!! funnnn....
          Robert
          New Rebuilt 3100
          New Rebuilt 4T60-E
          Exhaust
          White
          5 Speed Swapped
          127,000
          Spec Stage 3 Clutch
          Emissions Deleted
            Let me look.......
            Those are NOT my pics, but those ARE Beretta pics.
              thanks for the pics.. what exactly are they showing?? is that the rusted bulkhead???
              Robert
              New Rebuilt 3100
              New Rebuilt 4T60-E
              Exhaust
              White
              5 Speed Swapped
              127,000
              Spec Stage 3 Clutch
              Emissions Deleted
                well just got inside from working on the Z... And yes it is rusted.. So Some Fabrication is now needed to get this to work again... There is a huge rust hole... Is this a common problem with these cars??
                Robert
                New Rebuilt 3100
                New Rebuilt 4T60-E
                Exhaust
                White
                5 Speed Swapped
                127,000
                Spec Stage 3 Clutch
                Emissions Deleted
                  None of my cars have ever had that problem (knock on wood) but I read about it a lot. Another place to look for rot is the rockers.
                    lol those are not gone but are rusted...
                    Robert
                    New Rebuilt 3100
                    New Rebuilt 4T60-E
                    Exhaust
                    White
                    5 Speed Swapped
                    127,000
                    Spec Stage 3 Clutch
                    Emissions Deleted
