Brakes feel Loose
  • Brakes feel Loose
    Replaces rear pads..rear rotors and calipers. Replace front pads and Rotrs. Bleed system 4 times. Cars pedal travels like 75% before grabbing...what could be wrong? I'm postitive there no air in the system. What sequence for bleeding. I bleed farthest from the master cylinder first...to closet than ABS unit.
    Any Help would be appreciated.
    1996 Dodge Ram 5.9/4x4
    1992 Grand Prix GTP LQ1/4t60-E
    1986 Monte Carlo SS 355-3-71SC /200r4
    I had the same problem... except I bled the brakes more like 12 times! You did bleed the MC/ABS unit right? Assuming you did that, they are probably 'okay'. I took mine into a shop, and they were like "what are you talking about? The brakes are fine!" I guess I just demand more from my car [shrug]. Take it for a short test drive first though (make sure there aren't any pedestrians ) See how well it stops from 20. Should be able to lock your seatbelt.
    Okay now, that's enough of that.
      Did you reset the rear calipers??
      I am back
      Mechanical/Service Technican
        I had a problem with my brakes, they felt spongy. one of the lines was collapsed
        -=Danny=-
