I'm having trouble getting rid of my old ones (probably from the factory 13 years ago) to install a goodridge set plus a new set of calipers. With the first one I did the hardline fitting was seized to the pipe so it twisted and sheared before I noticed it. I know I have to replace that whole line now. I tried the other front one and I can't get it loose and nearly rounded the hardline's fitting. I get the feeling that the rear ones aren't going to be any easier so any suggestions? My first impulse was to use a propane torch to heat the fittings up a bit but I'm not too sure if that's a good idea. For now I'm just soaking them in wd-40.
Also, I stripped the threads for a caliper bolt on one steering knuckle. Is it safe to use a helicoil or should I just get another knuckle? I hoped iron was tougher than that...
