Im trying to replace a single lower subframe bushing behind the front passenger tire... I have the bolt out and the metal spacer and it wont drop down! Ive trying prying it with a screwdriver and prybar but its ON there... what am i doing wrong? I NEED to get this bushing off for my other car. thanks
Subframe bushing stuck
did you only loosen that one bolt? maybe that's why.Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
You need to drop the subframe down, by removing the other rear bolt and loosening the front 2. They are pressed in best I recall. You will have to beat them out. I put all new bushings and sleeves on my 91 and I had the benefit of the subframe being out of the car.Ben
