I so stupidly ran over a scissor jack in my driveway. I was barely rolling, clutch not even all the way out but it caught the edge of the tire and managed to cut through the tread and all the way down the sidewall, through the steel belt and all. Given that the rest of the tires have 20-30% life left it makes no sense to replace 1 tire. So I think I need to replace all four.
Here is what my needs are:
-The car is only summer driven so all season tires not necessary.
-I'd like a semi-performance oriented tire.
-Decent tread wear, say at least 40k miles.
-I don't want to break the bank and don't need top of the line but I also don't want bottom of the barrel.
Wheels are factory GP crosslace 16x8, the factory size tire is 245/50/16 and I'd like to stick with that size.
So what do you all recommend, where did you get them and what did they run you?
This has to be the least favorite of car services: its expensive, pretty much the only one I can't do myself, I have to let some punk kid drive my car and he'll probably torque my lugs to 300 ft lbs.
Also, I had a 4wheel alignment done not 5000 miles ago. I'm almost considering buying tires online, seems that is the cheapest route and bringing to a tire shop for mounting/balancing and then I can install the wheels on the car myself. Someone feel free to talk me into that.
