D.O.H.C. asked me to take some pics of the brakes on the 92, so today I finally got around to it. Besides, it was a good time to pull the front tires and grease my greasables (ball joints, tie rod ends, poly sway bar bushings). What is pictured here is the kit that is installed on my car with the 13" front, and 12" rears.
The fronts:
The only thing that holds the front calipers to the car, a pin with a "c" clip on the end...
Pin removed...
Caliper swinging out of its groove.
The groove the pin sets in.
Anti rattle clips to keep them from making tons of noise since they are full floating.
The spacer is .4 inches thick
The "cup" that is held in by the axle nut is .25 inches thick
The rears:
Apparently over time a parking brake cable can wear off the threads on adjustable ride hight rear struts/springs...
The adapter bracket
The whole collection of pics since I have no idea what resolution these are going to post at:
The fronts:
Pin removed...
The rears:
The adapter bracket
