Ran into something kinda wierd. I put KYBs all the way around on my 99 Lumina, basic model, doesn't even have ABS. When checking things out I noticed that the front struts looked alot like the front struts on my 93 Z34. In fact they're the same part number. Now in all the years I've been playing with W-Bodies I've been under the impression that in 97(?) they changed the front ends and you had to pull the whole strut-tower in order to change out the struts.... I figured that since the part numbers matched I'd try to change them the same way I do the 93 Z34, with the car on the ground and removing the plate on top of the tower and going in through the top. Worked like a charm!! Why would everyone say you have to remove the whole strut-tower to do the job (on 97++)??? I mean the struts went in with no problems and the job was done exactly the same way as my Z34,,, using the same tools. I'm not having any problems with the struts,,, OR complaining(!!),,,, just kind of wondering why they say you can't do it the same way........
Tom......
PS: WHAT a difference the KYBs make!!!
Tom......
