any poly control arm bushings out there???
  • any poly control arm bushings out there???
    title pretty much says it all application is gen 1 w-body.
    I'd be down, but what I really need is customer bult control arms that move the ball joint mount up. You rig those up and they'll sell. Anyone who's lowered needs them to correct suspension geometry.
      hmm that explains the tire wear then. all this time i thought it was the 400 lb springs and the triple digit curve speeds . pm me your research and and what exactly needs to be done and i will see what i can come up with. as my gtp is pretty much slammed too.
      p.s. i take it there are no poly control arm bushings out there?
        I have poly bushings. But I would NEVER use them again. They are the noisiest junk I have ever used. I would only use them again if they were greasable.
        As for moving the ball joint up. That may be easier than you think. Check out Howe Racing http://www.speedwaymotors.com/p/4791...ll-Joints.html They make increased height joints and may be able to help you. The other way to do it is to make a plate to fit under the joint and raise the whole thing up.
          what are the part numbers for your poly control arm bushings??????? plz!?
            It is a MUST to gease ANY poly-bushings. EVEN engine mounts or they are noisy!
            1991 Grand Prix STE
            3.4 DOHC
            1 of 792 Produced
            Extensive Mods Done
            1991 Lumina Z34
            3.4 DOHC
            Getrag 284 5spd
            1 of 30
              Well I looked at their list, they don't seem to make anything that would work on a Gen 1 suspension, unless you were implying they could make a custom ball joint?
                what about graphite impregnated poly?
                btw, the speedwaymotors warehouse is in my hometown....10 minutes from me.
                I know a guy who is a graphics designer there.
                  sweet, holla at them and see what they can do. while you are at it ask about engine mounts too .
                    can you clarify exactly what you want....pics and such....just wanna have all the info you want before I look like a dunce and walk in there and not know what i'm talking about.
                      ooh, yeah, engine mounts
                      zzp makes poly trans mounts for the 65's. 60's and 65's have the same part numbers, but read the description in the link
                      The largest supplier of aftermarket performance parts for 3800, Ecotec, Sonic/Cruze, and ATS vehicle platforms. We engineer unique parts in house that you won't find anywhere else!
                      91 GTP HM-284 GONE
                      96 Special Edition LQ1/4T60E GONE
                      98 Spawn of Satan (L67 Regal)
                      87 V10 SM-465/Mild 350
                      06 Cobalt SS/SC GONE
                        poly front control arm bushing is what i need. if you feel the need, get a set from an auto parts store and i'll re-imburse you.
                          I have an S-10. Not quite the same. But check out energy suspension. My buddy got Energy Suspension bushings from them for his Cavalier.
