title pretty much says it all application is gen 1 w-body.
any poly control arm bushings out there???
hmm that explains the tire wear then. all this time i thought it was the 400 lb springs and the triple digit curve speeds. pm me your research and and what exactly needs to be done and i will see what i can come up with. as my gtp is pretty much slammed too.
p.s. i take it there are no poly control arm bushings out there?Last edited by dohcfiend; 04-16-2007, 11:00 PM.The Official Rotating Mass Nazi
I have poly bushings. But I would NEVER use them again. They are the noisiest junk I have ever used. I would only use them again if they were greasable.
As for moving the ball joint up. That may be easier than you think. Check out Howe Racing http://www.speedwaymotors.com/p/4791...ll-Joints.html They make increased height joints and may be able to help you. The other way to do it is to make a plate to fit under the joint and raise the whole thing up.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
It is a MUST to gease ANY poly-bushings. EVEN engine mounts or they are noisy!1991 Grand Prix STE
3.4 DOHC
1 of 792 Produced
Extensive Mods Done
1991 Lumina Z34
3.4 DOHC
Getrag 284 5spd
1 of 30
Originally posted by HayesPerformance View PostIt is a MUST to gease ANY poly-bushings. EVEN engine mounts or they are noisy!
btw, the speedwaymotors warehouse is in my hometown....10 minutes from me.
I know a guy who is a graphics designer there.
Originally posted by dohcfiend View Postsweet, holla at them and see what they can do. while you are at it ask about engine mounts too.
ooh, yeah, engine mounts
zzp makes poly trans mounts for the 65's. 60's and 65's have the same part numbers, but read the description in the link
96 Special Edition LQ1/4T60E GONE
98 Spawn of Satan (L67 Regal)
87 V10 SM-465/Mild 350
06 Cobalt SS/SC GONE
Originally posted by AWeb80 View Postcan you clarify exactly what you want....pics and such....just wanna have all the info you want before I look like a dunce and walk in there and not know what i'm talking about.The Official Rotating Mass Nazi
Originally posted by dohcfiend View Postwhat are the part numbers for your poly control arm bushings??????? plz!?1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
