front sway bar end bushing size????
  • front sway bar end bushing size????
    what are the size of those end bushings on a dohc w-body? they do not look like the 34mm middle ones.
    23mm I think. Its been so long...
      for the 3.4 DOHC
      Front is
      24mm on the outside - Energy Suspension #9.5160
      and
      34mm on the inside - Energy Suspension #9.5167
      (its a 33mm, thats what they use cause they don't make 34mm)
      1991 Grand Prix STE
      3.4 DOHC
      1 of 792 Produced
      Extensive Mods Done
      1991 Lumina Z34
      3.4 DOHC
      Getrag 284 5spd
      1 of 30
        you read my mind
          while i am at it, are there any ES control arm bushings out there?
          and 7/8 rear sway bar bushings???
            unaware of CA bushings.
            Rear outer sway bar bushing/bracket (have to drill out holes some): 9.5158
            rear inner you cant get from ES, you have to use brickyard monte carlo bushings (they had a 7/8" bar): 10270253
            91 GTP HM-284 GONE
            96 Special Edition LQ1/4T60E GONE
            98 Spawn of Satan (L67 Regal)
            87 V10 SM-465/Mild 350
            06 Cobalt SS/SC GONE
              im have an addco rear sway bar but haven't installed it yet. it seems to use 22mm bushings but i just need to find the endlinks. i'll probably just take one to an auto parts store and match something up.
                yep, 22mm or 7/8". they arent really end link per sey. my local auto zones carry 7/8" es bushings/brackets in stock as well as some other sizes. what are you going to use for the inners?
                91 GTP HM-284 GONE
                  34mm ones from ES. i broke down and ordered every one i need from summit.
                    i was actually asking about the inners for the addco bar
                    91 GTP HM-284 GONE
                      22mm or 7/8 bushings.
                        so, youre going to hack up your factory brackets to make them work? i would just get the brickyard 7/8" bushings. if you hack them up like in the addco instructions, they will break.
                        91 GTP HM-284 GONE
                          i haven't installed them yet but i was under the impression the 7/8 bushings would fit into the addco brackets, if not i think they came with brackets.
                            the ones they provide are in a d shape to fit in the brackets they provide. i guess you might be able to round them off with a bench grinder and get them to fit in your stock brackets. i wouldnt do what they recommend in the instructions. youll see what im talking about
                            91 GTP HM-284 GONE
                              actually, i won't i bought it used w/no instructions . i have't gotten around to installing it or the bushings yet but i am sure once i do, what you have said will probably make perfect sense to me then.
