Could we, should we have a meet?
  • no pictures yet?? I FEEL CHEATED!
    I modify stuff
    • i iz also waiting, but brad did list the link for it...
      • OBTW... if y'all think the twisty road in ForcedFirebird's link was impressive... you should spend a weekend chasing me through the NC mountains. :-p I could show you some awesomeness... both for the view and the extreme twistiness.
        60v6's original Jon M.
        • Yeah, I'm slow. I know. I've had to do a lot of errand running since I got home. The footage is on my computer, I just need to get to editing it.
          • Well the damage to the Bimmer isn't as bad is I had anticipated
            Have to replace the drive shaft center bearing ($30) and I'm going to go ahead and replace the guibo while I'm at it. The wheel hop I was getting is worn rear subframe bushings, they are only $30 each, so I'll replace those with poly soon too.
            I was happy with the car for the trip. Almost 24yrs old, ~90k miles, all original then took it ~1k miles, 10 drag pulls, then another ~1k miles and have only $80 in damages, saweeet!
            And here everyone tells me owning a Bimmer is expensive hehe. $3400 for the car and so far have only had to replace the fan clutch in 3 yrs? ($20)
            • like i need more excuses to like BMWs...
              • Originally posted by robertisaar View Post
                Does that help?
                • Originally posted by pocket-rocket View Post
                  if by help, you mean want even more? YES
                  • Jon, I have seen that vid, but this is my fav (wonder why, the light blue car looks familiar eh?)...
                    • needs tuning.... badly. smoke when the throttle is snapped open and closed....
                      • M3 e30 4cyl 230hp...
                        More e30 fun (can;t wait to put my new top end on!!!)
                        And my car will run with a cam and said new top end...
                          Um, turbocharged cars do that my friend
                          Best if running slightly rich at/just off idle, and then when you have a fuel ratio of 12.5 and snap the throttle closed, takes the ECM a second to catch up and go decel. Much like watching a wideband at actual readings instead of delaying them to every .3 secs or whatever you prefer.
                          240kph = 150mph
                          • Originally posted by ForcedFirebird View Post
                            right, but it seemed a bit excessive even considering the application...
                            retard the spark a little more and instead of smoke there would have been flames...
                              The application is 100hp per hole. I would say that's pretty impressive
                              Either way you are trashing o2 sensors.
                              Still, next year I would rather be racing the 'Bird
                                That thing was nuts! I've always liked Bimmers. I would love to have an E36 myself. Love dem cars...
