I have been working on some new items for the 60V6 engines. These are designed to simplify engine swaps into other vehicles such as MGs, sand rails, etc and will be available in the near future. The first model uses a stock clockwise rotation waterpump, dampner & pulleys from a RWD. The WP inlet faces to the front to reduce hose clearance issues normally found on the RWD models. The second model is setup to use an aftermarket electric waterpump and FWD dampner. Both models have mounting features for an external CPS for those wanting to use one. Also, either unit is designed to fit any pushrod 60V6, including the LZ engines but VVT must be disabled.
The front engine mounts are poly, allow more side clearance, easy to mount and look really sharp.
Stock WP version
Electric WP version that has been glass beaded
Near future products will be:
Billet ALT brackets
Reworked 3.1 valve covers that are ballmilled and will fit GEN3 engines
VVT elimination kit for LZs
TB adapters for LZs
I belive that all items will be available through the 60V6 store.
Stock WP version
Billet ALT brackets
TB adapters for LZs
