Awesome site!
I bought the Isuzu Trooper with 3.4 in it.
The crank broke between the #2 rod and #2 crank main.The crank wedged forward and broke the block at the #1main bearing.
Timing cover is broken,harmonic balancer broke.
I will be getting another block in 2weeks,my questions now after reading the 2.8-->3.4 swap are.
Since I'm running a serpentin belt I will need the cover off of a 2.8 with serpentin/v-belts?
The Harmonic balancer will need to be a neutral balance correct,off of either a 3.4 or can I use one off a 2.8 since the flywheel is off a 2.8?
I don't want to spend $200 on a new balancer,if I can find one that is in good shape and pull it myself.I have a harmonic balancer remover/installer tool,no hammers etc here
Does anyone have GM part numbers or somewhere I can look them up on line?
#'s for:
timing covers
harmonic balancers
flywheels
TBI injectors
That type of stuff.Easier to id at JY's
Thanks for help,I'll have more questions and will link this site around some if it's ok with the Mod's.
Thanks
TurtleMechanic
#'s for:
timing covers
harmonic balancers
flywheels
TBI injectors
Thanks
TurtleMechanic
