Some time ago earlier this year during a discussion about the 3500, I missed some additional information on the GM drivetrain site that lead me to believe I had a steel crank in my 3500. Turns out that the steel cranks were designated for the Buick SUV.
While trial fitting the 7x reluctor ring for my about to be turbocharged 3500, I couldn't help but notice how silvery the crank looks, and how heavy it is. A trip to the scale with both the 3500 crank and a 3400 crank yielded the following;
3500 crank: 50 lbs, 3400 crank: 37 lbs.
The only numbers liking to a part number were on the tip of the crank snout;
5010300 and 7484. I didn't get a hit on the parts site but discovered that GM only showed one crank for the type 3500 I have #12577484 until 2006 where I found a listing for #12568259 a fairly cheaper crank. I called GM parts and although they couldn't tell me which crank was steel, they did tell me that the 7484 crank that I have weighs 49 lbs 1 less than I measured and the cheaper crank available in 2006 weighs 45 lbs.
These cranks are found across both the 3500 and 3900 in passenger and SUV vehicles as proposed sometime ago could be a possibility despite what they actually advertised which would be a marketing strategy if you thought your vehicle was the only one that came with it.
So either the more expensive and heavier 7484 is the steel crank or the cheaper lighter crank is the steel crank that's just making up for it's lighter weight and lower mass with it's increased strength assuming it is drilled in various places for lightening it to the tune of 45 lbs.
What do you think?
The twins
What do you think?
The twins
