Alternator swap
  • Alternator swap
    I have put a 95 Z34 motor in my 93 Grand Prix. Since I didn't change the front timing belt mounting I have to use the 95 alternator. So far I have blown two alternators. Any ideas on a fix. They both have two wires in their respective plugs. George
    RE: Alternator swap
    What's blowing on them?
    It may not be a mounting issue, cause well, if you can get the belt to run it, it's not a mounting problem.
      RE: Alternator swap
      I think there is some sort of adapter to use that plugs into the alternator between the stock wiring and the plug in. I honestly don't know if it is what is needed but its CS130 to CS130D? I know there is an adapter for something when using a different alternator but since I didn't have a use for it I didn't remember much on it.
      thats what I found. Dunno if it would be of any use to you.
