I'm set on using a 3.4l from a 93-95 camaro for our rockcrawler project.
I've been told that i can use the 93-95 SFI 3.4 engine (OBD I i'm assuming) in conjunction with a 3.1 computer from a Beretta or similar, but some alterations will have to be made to the camaro wiring harness.
I'm decent with wiring, troubleshooting, etc, but i'm not sure where to start or what will work? Are my assumptions of the engine/ECU combination correct?
What, if any, alterations will need to be done to the wiring harness? Should the beretta harness or the camaro harness be used?
I'm looking for the best performance, so will injectors, or any modifications to the ECU be necessary?
I'm a little lost. I guess I'll "rephrase" myself....
If i want to use the 3.4 from a 93-95 camaro in a rockcrawler....
What's the best harness/ECU to use and what modifications will I need to undergo?
Thanks.
Conn
Thanks.
Conn
