92 3.4 DOHC into a 95 Z34 with 3.4 DOHC
  • 92 3.4 DOHC into a 95 Z34 with 3.4 DOHC
    I have a 95 Z34 and I bought a 92 3.4 DOHC wich was remanufactured, can I put the cam sencores and cranck sencores and the intake manifold off the 95 on the 92 and use it.
    RE: 92 3.4 DOHC into a 95 Z34 with 3.4 DOHC
    Intake manifold is the same. You will need to swap the front cam carrier and the timing chain cover for the cam/crank position sensors that your 95 requires to run.
