hey everybody, i'm new here (and sorry for the long post)... i've been looking into engine options for my next project car, its going to be an opel manta, '71-'75 (since i already have one opel). stock, they come with a cast iron 1.9L 4 banger, heavier than some aluminum V8's, it puts out a whopping 85hp or so, but the car only weighs a bit over 2000lbs.
i work at a performance/car audio shop and one of the guys i work with has a 91 civic hatch that can do the 1/4 mile in 12.6 @ 107 mph, and hes pretty proud of it. so i'm wanting to show him up a bit, just because thats the kind of guy i am... that and i've always wanted to build a drag car
i think i have a fair chance, i have the advantage of rear wheel drive for traction and we're more or less the same weight
i was origionally thinking of dropping in a V8, but i want to keep at much weight off the front end as possible, so i'm trying to decide between a turbo'd, built up origional engine, or a 60 degree V6 (probably 3.4L), which is the only other reasonable priced engine that will fit in there and be worth my time that i have found... or maybe a turbo V6?
anyway, i've got a few questions for you:
1) i looked at the transmissions in the left menu there, and i'm wondering if there is any 6 speed trans that will either bolt up to the engine, or be modified to fit without too much work?
2) does anyone know the weight of the engine with all the basic parts needed to make it work?... like wiring harness, ecu, intake components so i can compare it to the origional tank of an engine
3) how well does the engine respond to turbo charging? i've got a bit of a background in fabrication, and have always wanted to have a turbo project... or maybe something crazy like a twin turbo, since there are a few pairs sitting around at my work that i could pick up for cheap... or would only 3 cylinders per turbo not be enough?
4) who thinks i can do it on a decent budget? i'm thinking i'll buy the engine, trans and everything from a wrecker as is and use it so i don't need to rebuild anything, i'll be doing all the fitting and fabricating myself... my goal is to build the whole car for less than $5000 canadian, including purchase of the car (about $400-$500, i already have a few beaters lined up for me to take my pick of this spring)
heres my run down of the prices:
purchase of the car, including transport to my house, $600
engine, ecu & wiring, probably from a mid 90's camaro/firebird, ~$1000
tranny, probably from an S10 since its shorter than the camaro and the car is very small ~$600
rear end, undecided on which, but preferrably independent with a LSD (any recommendations?), i would guess $500 at most though
turbo parts and piping, if i decide to go with that, less than $800
exhaust, ~$300
half assed body work (weld new sheet metal to cover the bit of rust the cars have, a bit of bondo, and some flat black paint), ~$300
and the other $900 go to random expenses, like the driveshaft modification and balancing
anyway, i'll stop rambling for a bit... let me know if you all think its possible to do on that budget, or if you have any reccommendations for anything
exhaust, ~$300
