CodeRedZ24's 3400 Swap Thread Updated Dec 1st
  • #16
    thanx
    Z24 Cardomain Site ll ZQ8 Car Domain Site
    • #17
      You only needed the coil bracket, just an FYI. The genII ICM and coils are identical to the genIII parts.
      I'm not sure if anyone has mentioned it yet, but you're going to need a different throttle cable bracket and throttle body linkage.
      Get these items from a 3100/3400 equipped car, such as '97 to '03 Malibu, Alero, Monte Carlo.
      The TB linkage can be swapped. So you can use the throttle shaft with proper linkage from a 3100 equipped car if need be.
      • #18
        yah i know i was only interested in the bracket but hey for 40 bucks i got the bracket and virtually brand new coils and module
        i know i need the throttle body cable and linkage i just havent gone to get them yet
        heres a question though
        i was told i need a few things for the auto trans to work when i swap the whole motor , if i decided to only swap the topend would i still need those items?
        • #19
          good deal. i bought a 3400 with 32k miles on it in mint condition for $200 locally. came out of a 02 buick van
          02 GTP - 90* > Failboat
          www.blackbombshell95.com
          • #20
            Good deal.
            Let me know when you need them, I think I have those parts around.
            Yes, either way you'll need to make somthing to get the TV cable to operate properly.
            Most people seem to get a Quad4 2.3 Cruise control box IIRC.
            I'm sure there is a way with the early 3100 TB from a Grand Am, that has an extra cable attachment, though it hasn't been done, yet.
            Has more info
            • #21
              When I did the throttle on my 3400 swap, I just swapped the linkage. It worked perfectly.
              1995 Pontiac Grand Prix SE - 3100/3400 hybrid
              • #22
                Good deal.
                Has more info
                hey if you already have the throttle parts let me know how much
                also i`m in need of a few pulleys
                i`m going A/C delete
                but need the idler pulley thats near the A/C
                tensioner pulley setup
                idler pulleyby the alternator
                and power steering pump pulley and resevoir
                • #23
                  NEW UPDATE
                  finally went back over to my brothers and pulled more of the motor apart
                  as you can see form the pics the inside of the engine is pretty sludgy
                  still need to pull the heads off here sometime started working on pulling hte exhaust manifolds off but need a deep well 13mm for the flanges and i broke one bolt off in the head (dammit) grrr
                  so bringing some of the parts back to my house so i can clean them up a bit and paint (whenever i get the time)
                  • #24
                    Holy extended OCI's!!! Looks like you're having fun with that, though. Can't wait to see it up and running.
                    • #25
                      Thats a terrible amount of sludge. I spent a lot more on my 5 year old 3400 than you did on that one. 3400 are extremely hard to find in my corner of the world. But it was super clean on the inside.
                      1991 Cavalier VL Coupe 3400 5 speed
                      • #26
                        well a few updates finally got a power steering pump and a few pulleys that i needed also won a auction on ebay for a plenum that says 3400 on it
                        • #27
                          well a few updates
                          i still need to contact a shop to get the motor cleaned
                          but got my power steering pump some miscellious bolts form a yard pulleys
                          and extra 3400 SFI plenum and throttle body i got off ebay (since the one i had didnt say anything on it)
                          so heres a few pics of the parts laying around at my house the block and heads are at my brothers
