Swaping LA1 in an 76 MG
  • #16
    Some of the stock starters (usually the older ones) are larger... in all dinmensions... The little one in the picture is the newest design... Possible that it might fit w/o modifications..
    Cliff Scott
    89 BerettaGT
    89 Volvo740
    Cliff,
    Could be true, I'm using an old style starter. Seems I read somewhere about the existance of an aftermarket starter that didn't have much of a nose on it that might work as well. The modification to use the old starter just involves grinding off some material inside the left starter pocket...about a 1" by 1" area.
    I can also tell you that the shifter on the T5 I'm using comes up through the stock location on the MGB but I had to cut and weld the shift lever at an angle so that it would be centered in the hole and shift into all gears without interference on the sides of the hole.
    Scott
    • #17
      Scott, do you have pictures of your install?
      • #18
        I do have some...what is it you'd like to see?
        Scott
        • #19
          hmmm, a pic of the engine used, along with the trans?
          maybe a finished pic of the engine installed.
          • #20
            Jeremy,
            Here they are. It isn't finished yet but it's getting there. I started it for the first time earlier this week.
            Scott
            • #21
              Originally posted by Scott_68B
              Jeremy,
              Scott
              WOW! that's the REALLY old style starter... (many revisions ago)
              Cliff Scott
              89 BerettaGT
              89 Volvo740
              Cliff Scott
              89 BerettaGT
              04 AleroGX
              • #22
                Originally posted by RidgeRunner
                Nice info, but would the older BW T5's be the same as what's in that .pdf?
                The short answer is I dunno. The T5's history only goes back to the early 80's and the early models were the Non-World Class or NWC models that were less desirable than later (WC) models.
                The guy at 5speeds.com has a forum and you could ask him about the older models.
                sg99
                He who dies with the most toys is still dead.
                • #23
                  Scott_68B:
                  Wow, very nice! Looks like it grew there as God intended.
                  What bellhousing is that?
                  sg99
                  OOPS, never mind. I reread your earlier post. Sorry.
                  • #24
                    sg,
                    Thanks. It does look like it belongs doesn't it? That is one reason I choose to go this route. The FWD v660 is such a compact package for the amount of power it is capable of producing.
                    Scott
                    • #25
                      Sheesh, the power to weight ratio on that will be awesome!
                      88 Fiero Formula 5-spd
                      Turbocharged / Intercooled 99\' 3100 VIN M
                      GMPCM - Engine Management System Tuning Software
                      • #26
                        Ok, Now lets talk Computer.
                        What Kind of computer would be best for my purpoces? ODB II that comes off the 3400 doner car? or some other combonation of sourts.
                        From what i understnad the ga computer controls the auto Trans, and mounting this to a T5 how would that work?
                        • #27
                          I put a 3400 in to my 84 cavalier that was carburated, I am running a 89 2.8 computer and it runs great! if you get a 2000+ engine you will have to re-wire the injector harness to match the one of the 2.8/3.1 harness
                          14.96@91.47 in the 1/4
                          9.63@74.36 in the 1/8th
                          • #28
                            Well, hate to sound like a broken record, but Dann Wade at killerbv6 has that all worked out too.
                            I read a thread in a British MG forum (that I found in this site's forum) where Mr. Wade and another fellow who both sell commercial kits were discussing their different approaches to this very question.
                            Seems Mr. Wade uses an older computer with the newer engine. The way it is done seems well thought out and straight forward.
                            Here's the link:
                            sg99
                            • #29
                              i would use the Gen2 3.1/2.8L ECM (87-94) the 7730 style ecm.
                              would be the easiest and best way to run the engine, you can get custom tuned chips for them, there is no concern of trying to bypass for a Manual trans with a Autotrans programed computer, its a simple setup, and parts/harnesses available at all wreckers everywhere.
                              however with using this setup you lose the SFI injection and have a MPFI injection setup. but unless your overly concerned with milage, i wouldnt loose sleep over the loss of the SFI.
                              Colin
                              • #30
                                smilinguy99 & v6h.o.
                                Thanks for the tips. I read the link smilinguy put up, its very informative, and Excatly what I was looking for.
                                Milage is not a problem on this project, MFPI will do just fine.
                                Thanks again guys
