Here is the deal I am swaping out my poor 2.8 carb engine to a 3.4 finally. I want to go to fuel injection. I am wondering about smog problems. I know the 3.4 motor is suppost to be not aloud in California, but what really matters is what comes out of the tail pipe.
I know the 3.4 will pass with a carb. All it is bigger bore bigger stroke and bigger valves. The only thing I am kind of worried about is the cam. I am going to try at work to smog it with the carb on it. Then go and smog it with tbi. Make sure it smogs with the carb first.
Now my question is how much trouble am I going to have conveting to fuel injection. Like I said I live in California so it's real tight around here about what comes out of the tail pipe.
Computer wire harness sensors. What else am I going to run into while converting to Tbi. Hight pressure fuel line?
I have done my research on the 2.8 to 3.4 swap, but have not found anything on 2.8carb to 3.4tbi swap. I have been a certified tech for sometime so you can talk to me as a mechanic and not as a newbee.
Thanks,
BlazinBeast
Thanks,
BlazinBeast
