New user here.
I have a line on a Lumina minivan that I could get cheap. I believe it's a later model since it has the chopped off front nose(95 or 96?). It has the throttle body 3.1 engine, and the engine is locked up.
I have another line on a 91 pontiac grandprix that I could possibly get cheap. It has the 3.1 multiport engine that is in good shape.
The ideal situation for me is if I could take the grand prix motor, take the MPFI off and swap the minivan TBI manifold and misc onto it, and then install it in the minivan.
Does anybody see any problems with this? I tried searching this site for some possible problems, and see there can be many depending on what you are doing. I have gathered so far that both blocks would be FWD style, so hopefully mounting would not be a problem.
Will the TBI van manifold fit to the MPFI aluminum heads?
Why did GM keep using iron heads on the minivan?
Does the TBI use a distributor(I haven't looked at this thing very close yet). If so, can I retro-fit the dist onto the MPFI engine?
If I have to swap the iron heads onto the pontiac block, that could be risky since the minivan supposedly overheated. That could mean a cracked or warped head. I am thinking that is probably why the engine is locked up, if coolant leaked into one of the cylinders(it's been sitting for awhile).
