i just got done with putting a 03' impala 3400 in my 88' beretta and yes its a 5spd, but im needing the cable and the coolant tank so what car's will work
3400 coolant tank and throttle cable
the coolant tank depends on your radiator, if you are using the 88's radiator then keep the same tank.
there are only two types of coolant tanks(i'm not sure what you have)
but there is pressurized ones, where you don't have a radiator cap, and you have to fill the radiator up via the coolant tank.
or unpressurized, where you have a radiator cap, and the tank holds no pressure, and you fill with coolant via the radiator cap.
as for the throttle cable, i would think the one from your 88's will work if it was originally a v6 car, but i'm not 100% sure on that.
also i would try to stay away from using a coolant tank off another car, simply for mounting ease. just use one from a beretta or corsica ect., and save your self a huge headache.
also i did some looking and it looks like your car came with a radiator cap, but i was looking at some guys that have done the swap and swapped over to the berettas later cooling system(no radiator cap), and honestly i would say thats the way to go, the 88's tank was ugly.
