For anyone that doesn't know I blew up my 3.1L running lean on nitrous.. I started doing a 2.3L HO Quad 4 swap about a month ago.. between lookin for a job and getting my schedual set, moving back home with the perents and getting settled I finaly found some time to give my baby some TLC.. I got heater core lines , power steering lines, shift cables, slave, brake master, thottle cable all done... I found I am missing a few small bits and pieces hopefully I'll be able to find them.. here are the pics..
Unfortunatly for a fellow BCJbody club member and good friend his car was writen off recently.. Thanks to his generosity my car now has new KYB shocks all around and new polly bushings up front.. I had also picked up some newish brakes off the beretta I got my motor out of and installed them..
I also pulled off my rear bumper and eye balled the GTZ bumper I have to see if it would fit.. looks like I just need to ream out the bolt holes in the bumper support and it'll bolt right up.. That should box out the rear end of the car a little more and help things flow a little better with my 87 front end conversion and 87 side skirts.. I should be firing up the car this weekend..
