3400 passes emissions test with no modifications
  • 3400 passes emissions test with no modifications
    Just thought I'd let everyone know that to my surprise, my 3400 in my '89 Beretta passed the emission test today. It was fairly close to the limit, but i didn't even expect it to pas with NO modifications at all, still running the original 2.8 chip. I've also been a little lax about changing the oxygen sensor as well, (as in, the 7 years i've had it i never changed it).
    Cliff Scott
    89 BerettaGT <- Good on emissions until 2007
    04 AleroGX
    Cliff Scott
    89 BerettaGT
    04 AleroGX
    Pretty cool. How does it run with the 2.8 chipset?
    1995 Grand Am GT
    3400 V6 / 4T60-E / Engine Swap
    3400 Engine Swap Guide Version 2.5 is Available!
    www.3400swap.com
      nothing better than getting passed the emission nazis
      1995 camaro 3.4 5-speed
        Lloyds 1990 3400 passed better than the 3.1L
          It runs acceptably on the 2.8 chip still.. I'm sure it's not optimal, but no stock chip is. I was just surprised that it passed the "IM240" test before the whole test was completed... now that i think of it, that is better than the 2.8 did.
          However, i do need a new ECM and some other stuff. out of the blue i'll lose any power whenever the accelerator is off idle, I just have to reach over and tap the ECM then it's back to normal.
          Cliff Scott
          89 BerettaGT
          04 AleroGX
          Cliff Scott
          89 BerettaGT
          04 AleroGX
            I scanned in the results if anyone cared...
            Cliff Scott
            89 BerettaGT
            04 AleroGX
            Cliff Scott
            89 BerettaGT
            04 AleroGX
              Interesting test results..... Check this article out. You may find it helpful....
              1986 Cherokee Wagoneer 4 door.
              2.8 Litre V6 TF904/NP228
              4.10 gears
                which injectors?
                  My injectors are what were in it. I didn't loosen a bolt on the engine i didn't have to. The engine was from a '99 Alero, so they're the Multec design (the style used from 87-99)
                  Cliff Scott
                  89 BerettaGT
                  04 AleroGX
                  Cliff Scott
                  89 BerettaGT
                  04 AleroGX
