V6/Porsche 914 project
  • #46
    Here are the lastest update pics of the project......haven't work on the car much since warm weather got here.....................
    latest and greatest re-inforcement of the rear suspention pickup points
    • #47
      rear control arms installed/new bearings and poly bushings with grease zerks
      • #48
        140# Eibach springs for the rear will go over Koni "yellows" with Ground Control adjustable spring perches.....
        • #49
          radiator/cooling fan is installed in the front trunk....
          • #50
            and last, a slot cut in the bumper area to bring fresh air over the radiator
            and out the bottom of the car. The air dam on the front should create a low pressure area behind it and help pull the air thru........(I hope)
            • #51
              Originally posted by Stevesr
              My "new "top end stuff.....Thanks again Brad!!!
              What? No thanks to the son who drove an extra 400 miles? Just kidding, your welcome, dad.
              -Steve Jr.-
              • #52
                You were just the middle man..........................
                SteveSr
                • #53
                  wow, i really like that. long time ago I owned a couple 914's amd looked at doing a SBC swap in one of them along with the rayco986 body kit. If I ever come across another I might just have to pick up another 914 maybe do a 3800sc swap in it.
                  87 fiero gt
                  3800sc/4t60e
                  1/8th Et 7.597
                  60ft 1.579
                  mph 88.53
                  • #54
                    A 3800sc would be awsome,you wouldn't have to do anything to the engine but swap it in......plenty of stock HP.
                    There is a guy in Seattle WA. that has a 3800 in a 914,I don't think it's supercharged tho.........http://members.rennlist.com/bluethunder/index.htm
                    SteveSr
