Can't seem to get a straight answer on this....
  • Can't seem to get a straight answer on this....
    Does anyone know what size tap I need for the lower intake manifold for the coolant return line for a 97 3.1 to a 00+ 3400 swap ? I've heard half inch and I've heard 7/8 npt Does anyone have a concrete answer ? Thank you
    If I can't get a solid answer I'll probably cut the tubes and connect them with clamps and rubber hose....just don't want it to look like a rigged swap
      Ben would know the size. I can tell you that it doesn't look good and that the hose may flex and then you get a leak. Been fighting with mine and I regret not tapping the lower.
      Grand Prix trans with 3.33FDR
        Yeah I had thought of that.....I'm sure someone will know......I'm having a hell of a time doing anything on my phone.....including searches..... My phones being an asshole
          1/2" NPT. Was going to take a pic of mine, but the numbers don't show up very well.
            1/2" NPT.
            Our smiley list is horrid. Also, that is correct:P
            /edit....I agree
              3400 swap guide ftw... same info.
              3400_Swap_Guide_v2.5.6.pdf
