03' Malibu with 3.1 needs engine, which 3.4...
  • 03' Malibu with 3.1 needs engine, which 3.4...
    Could I install with minimal modifications? Any help would be extremely appreciated!
    yep, pretty direct swap. make sure to use your brackets n exhaust mani's
      What years work? use same year 3.4 from impala?
      I want to make easy as possible
        stick with an 2003 01 Malibu 3100 for easiest swap.
          if I have to put a engine in, I want a 3.4. I don't care about manifolds. I just don't want to rewire cam sensors etc...
            Swapping uim tb exhaust manis alt bracket and engine mounting brackets are typically the parts needed for the change from a 00+ 3100 to a 3400 & vice versa.
              What is UIM? Also since the car is a 03 i was going to use a local engine from a reputable salvage yard that has a 03 impala 3.4 But they tell me 03 is a one year only interchange. Would anyone know the difference between it and other years?
