3900 into 2005 subaru legacy AWD
  • #46
    Looking good! Best part about this swap is that it fixes the subaru miss fire sound! Lol
    14.96@91.47 in the 1/4
    9.63@74.36 in the 1/8th
    • #47
      lol like mine
      • #48
        Custom notched oil pan all tigged up
        • #49
          Turbo placement ?
          • #50
            Custom pilot on route
            • #51
              Originally posted by farmerz24 View Post
              Turbo placement ?
              Plenty of room, lol
              • #52
                First test fire on full sequential and coil on plug successful
                • #53
                  I may have missed this.. Are you going to run the stock holset VGT actuator or do you plan on pinning the sector gear and using an external wastegate?
                  • #54
                    Some guy made a 0-5v controller for the vgt as it is can bus communication. The 5v output from the ms-pro will control this. I will run an external gate as well unless the vgt can bleed down the boost.
                    • #55
                      Boom
                      • #56
                        • #57
                          wow; ambitious beyond my imagination. Congrats on the work so far.
                          What are you doing about a PCM, just in case you are making any use of the stock one?
                          (if you can't tell already I'm looking for LZ9 pinout diagrams...)
                          Will keep watching this; it is a great build.
                          GP
                          • #58
                            Stock one is being used to control the gauges and work the electronic drive by wire tb.
                            Using a mega squirt ms3 pro
                            • #59
                              Rev video
                              • #60
                                So I guess it is safe to say that this engine can start with vvt in the default position
