I was thinking of how cool it would be to have an rx7 fc powered by a 3400 sfi. I heard the engine bay is a tight squeeze, can anyone confirm whether or not there is room? Also, if i used a t-5 or 700r4 would the shifter be in an odd unmanageable location? Anyone with any info will be appreciated.
Will it fit?
I believe it will fit, even without needing to notch the crossmember or oil pan. I measured about 13" from the crossmember to where the stock bellhousing sits. (There's an FC sitting in my shop right now).
Since people do V8 swaps in them it's reasonable to assume that a car T5 will have an appropriate shifter location.'89 Firebird, 3500 Turbo, T56, 9-bolt/4.11
'86 Fiero, 3500, 4-speed
LS1/T56 is pretty much a bolt-in deal with a kit that you can buy. 60v6 would probably be just as easy other than making the mounts.
