I tried searching, but wasn't able to come up with a definitive answer to my question.
I picked up an 04 Grand AM with the 3400, it needs a new engine, as the block is cracked because the previous owner used water instead of antifreeze.
On my local craigslist, I've found a 99 3400 out of an Olds Silouhette van, will this engine work or not. Changing parts between blocks would not be a big deal since I'm going to rebuild the motor before it goes into the car.
Thanks for your insight!
